GE Profile Dryer, when selecting various fabrics to dry the time would adjust and change. For example cottons on high heat, more dry, would take 45 ish minutes on the timer, now only shows 35. Towels would show 55 ish minutes and now only shows 36 minutes for "more dry" "high heat." The clothes also have to be dried twice or on timed dry for at least 60 minutes on high heat. So I've ripped the dryer apart and tested all the sensors and here's the results of each sensor which I will refer to by color in the pictures i've attached. Heating Coils: Each show continuity and about 22 Ohms resistance. Blue Circle Sensor 0 Ohms Green Circle Sensor 99K Ohms Red Circle Senor 0 Ohms Gray Circle Sensor 0 Ohms Purple Sensor Room Temperature 100K Ohms Hair Dryer Blowing On it Constant decrease but I stopped at 60K Ohms Moisture Sensor With dryer running and no damp fabric across bars, showed about 2.18 VDC at the quick disconnect plug. With dryer running and wet cloth across bars, showed 0.7 VDC at the quick disconnect plug. Heating Coils Operation When dryer turns on and on "high heat", the single coil of the 3 comes on for about 2 minutes and off for 2 minutes and so on. Air on discharge feels hot but didnt get a temperature reading. I didn't have any wet clothes in there so wasn't sure if that would cause the other 2 coils to come on. Air ducts are clean. So I think I have tested almost everything, anyone got ideas on which sensor is bad? Unforgiven attached the following image(s):
nobody? anything? is it the one sensor that doesnt read 0?
