When the refrigearator motor shuts down it makes a loud terrible racket and shakes. What might be the problem?? Perhaps bearings in the motor are bad. Don't know for sure.
I am not sure what motor you are referring to. If you mean the compressor then yes it is on it's last legs. I would check it's rubber mount just to be sure they are OK.
It may last a couple days, it may last a year or more but it is no longer reliable.
To replace it will be an expensive repair as you need a pro. Internal parts of a compressor are not replaceable. Usually it makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
Yes on Compressor.....Thank You.:) Originally Posted by: denman I am not sure what motor you are referring to. If you mean the compressor then yes it is on it's last legs. I would check it's rubber mount just to be sure they are OK.
THANK YOU. Yes, it was compressor .........:)
