rhb2340
#1 Posted : Sunday, August 18, 2013 10:48:24 AM(UTC)
rhb2340
When the refrigearator motor shuts down it makes a loud terrible racket and shakes. What might be the problem?? Perhaps bearings in the motor are bad.
Don't know for sure.
#2 Posted : Sunday, August 18, 2013 1:17:05 PM(UTC)
I am not sure what motor you are referring to.
If you mean the compressor then yes it is on it's last legs.
I would check it's rubber mount just to be sure they are OK.
It may last a couple days, it may last a year or more but it is no longer reliable.
To replace it will be an expensive repair as you need a pro.
Internal parts of a compressor are not replaceable.
Usually it makes more sense to put the dollars towards a new unit.
rhb2340
#3 Posted : Sunday, August 18, 2013 4:25:42 PM(UTC)
rhb2340
Yes on Compressor.....Thank You.:)
rhb2340
#4 Posted : Sunday, August 18, 2013 4:27:34 PM(UTC)
rhb2340
THANK YOU. Yes, it was compressor .........:)
