mattphp1
#1 Posted : Saturday, August 17, 2013 7:38:55 AM(UTC)
mattphp1
I need some help. I have a dryer that keeps giving me PF codes and not finishing the cycle. It will start just fine and then I come back to the dryer and see the PF code. Any insight would be helpful!
Matt
HumboldtRepairMan
#2 Posted : Saturday, August 17, 2013 8:18:21 AM(UTC)
HumboldtRepairMan
PF is just power failure because your electricity went off or breaker tripped............try finding another code with it.
mattphp1
#3 Posted : Saturday, August 17, 2013 8:42:17 AM(UTC)
mattphp1
Neither happened. I took it apart and ran the troubleshooting guide. There were no stored codes. I checked the moisture sensor and the thermistor and they checked out good. The resistance on the thermistor was 8.5kOhms.
I don't get the error every time I run the dryer but most times. Think it may be the electric controller?
Any thoughts?
HumboldtRepairMan
#4 Posted : Saturday, August 17, 2013 1:02:22 PM(UTC)
HumboldtRepairMan
Anythings possible with a main controller it's either that or a short or component out somewhere but they usually don't do that with a component problem unless you have a power filter board so if you have that check that.
