I need some help. I have a dryer that keeps giving me PF codes and not finishing the cycle. It will start just fine and then I come back to the dryer and see the PF code. Any insight would be helpful!
Matt
PF is just power failure because your electricity went off or breaker tripped............try finding another code with it.
Originally Posted by: HumboldtRepairMan ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) PF is just power failure because your electricity went off or breaker tripped............try finding another code with it. Neither happened. I took it apart and ran the troubleshooting guide. There were no stored codes. I checked the moisture sensor and the thermistor and they checked out good. The resistance on the thermistor was 8.5kOhms. I don't get the error every time I run the dryer but most times. Think it may be the electric controller? Any thoughts?
Anythings possible with a main controller it's either that or a short or component out somewhere but they usually don't do that with a component problem unless you have a power filter board so if you have that check that.
