ros352
#1 Posted : Tuesday, August 13, 2013 9:44:38 AM(UTC)
ros352
I have a Kenmore gas dryer which worked perfectly fine up until a few days ago. All of a sudden it chipped out and when I try to start it again it chips out again. Every time I try to start it; it runs then chips out. What should I do? Has it run its course or is this problem fixable?
HumboldtRepairMan
#2 Posted : Tuesday, August 13, 2013 11:11:06 AM(UTC)
HumboldtRepairMan
Chips out? never heard of a unit chipping
ros352
#3 Posted : Wednesday, August 14, 2013 4:47:41 AM(UTC)
ros352
When I say chipping out I mean that the motor will just stop after a brief time of running
HumboldtRepairMan
#4 Posted : Wednesday, August 14, 2013 5:37:55 AM(UTC)
HumboldtRepairMan
Then you got a bad motor or main control board most likely........Take a voltage reading while running the unit and see if the supply is cutting off if the 120v is dropping during this happening then it's a bad connection or harness issues or a bad main board.............if the supply is good and steady 120v then it shuts off then it's probably your motor..........watch a youtube video on how to diagnose. Good luck
