mmrosebush@aol.com
#1 Posted : Monday, August 12, 2013 8:16:58 AM(UTC)
mmrosebush@aol.com
We purchased a GE Nautilus model # GSC3400J00BB. It will drain after the wash cycle, but then when it fills to rinse, it will not drain and goes right into the dry cycle. Any suggestions??? :confused:
HumboldtRepairMan
#2 Posted : Monday, August 12, 2013 11:33:09 AM(UTC)
HumboldtRepairMan
Your model you have is very cheap and problem proned........here are the schematics for your pump area and some video's that will give you an idea what to test........you should have 120v at the sump pump and drain pump when it's in the cycle.......if you don't you may have a main control issue not sending the right electricity to component........
Motor-Pump Mechanism parts for GE GSC3400J00BB - AppliancePartsPros.com
https://www.youtube.com/watch?v=oLPBlkIsB5s
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
won't drain completey (Washer Repair)
by Guest 2/5/2023 11:06:41 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
GE top load won't drain or spin (Washer Repair)
by Guest 2/15/2022 10:42:41 AM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Won't drain automatically but it will drain if set manually to spin cycle (Washer Repair)
by adanpro@gmail.com 6/1/2021 6:47:55 AM(UTC)
Kenmore he 3T won't drain/spin, F2 (Washer Repair)
by corvairdoug 8/20/2020 2:23:35 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Won't drain,rinse or spin. (Washer Repair)
by dertikop 3/25/2017 5:46:57 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Maytag won't drain... (Washer Repair)
by HyKlas 2/21/2017 5:34:29 PM(UTC)
