ScottKr
#1 Posted : Saturday, August 10, 2013 10:55:48 AM(UTC)
ScottKr
I have a GE gas dryer that I've been trying to fix which has no heat. I did some troubleshooting based on information from the forums and decided to order the gas valve coil kit. I replaced the two gas valve coils but still don't consistently get ignition. I have seen the system ignite, but it seems to be very sporadic.
If I unplug the dryer, then plug it back in, and start it I can see the igniter glow for about 10 seconds. But I get no flame.
After this happens, the igniter will not glow until I unplug the dryer again. Maybe this is some kind of safety since it knows it did not light previously?
Any ideas?
HumboldtRepairMan
#2 Posted : Saturday, August 10, 2013 1:43:01 PM(UTC)
HumboldtRepairMan
sounds like even though your ignitor glows temporarily maybe it's not pulling enough amps to release the gas valve...........you'll need an amp clamp meter and watch a youtube video on testing gas dryers......Good luck
ScottKr
#3 Posted : Friday, September 20, 2013 8:09:12 AM(UTC)
ScottKr
If the igniter is not pulling enough amperage would it be the igniter that gets replaced or another item?
HumboldtRepairMan
#4 Posted : Saturday, September 21, 2013 8:24:26 AM(UTC)
HumboldtRepairMan
Could be a number of things watch this video
Gas Dryer Repair Video: Heating Problems - YouTube
