Hello guys,
at first i would like to apologize for my bad english. I have an issue that look like an defrost problem. After 2-3 days the evaporator is completley frozen and the temperature of the freezer und refrigerator still getting higher.
How can i trigger a defrost by this model? Has anybody an wiring/circuit diagram or other information?
Best Regards from Germany, Thorsten.
Here are your parts includes a wiring diagram Parts for Amana XRSR465BW / PXRSR465BW0 - AppliancePartsPros.com[COLOR="Blue"]How can i trigger a defrost by this model?[/COLOR] Looks like it uses a defrost timer (item 9 in section 02). Turn the timer cam till the compressor and fans shut off. You are now in a defrost cycle. There is usually a hole in the covers that will let you turn the cam without taking things apart. Also the cam will only turn in one direction. |
THIS FORUM IS DEAD!!!!!!! |
