frig_toto
#1 Posted : Tuesday, August 6, 2013 2:44:55 AM(UTC)
frig_toto
Hello guys,
at first i would like to apologize for my bad english.
I have an issue that look like an defrost problem. After 2-3 days the evaporator is completley frozen and the temperature of the freezer und refrigerator still getting higher.
How can i trigger a defrost by this model?
Has anybody an wiring/circuit diagram or other information?
Best Regards from Germany,
Thorsten.
#2 Posted : Wednesday, August 7, 2013 1:56:02 AM(UTC)
Here are your parts includes a wiring diagram
Parts for Amana XRSR465BW / PXRSR465BW0 - AppliancePartsPros.com
[COLOR="Blue"]How can i trigger a defrost by this model?[/COLOR]
Looks like it uses a defrost timer (item 9 in section 02).
Turn the timer cam till the compressor and fans shut off. You are now in a defrost cycle.
There is usually a hole in the covers that will let you turn the cam without taking things apart. Also the cam will only turn in one direction.
