nixima
#1 Posted : 12 years ago
nixima
Bosch dishwasher is about 9 years old and I installed a new control module (PN 488428) and now I am unable to disable the end of cycle alarm. When I hold down the two cancel buttons and then the on/off button I get a red light on one of the buttons but I never hear a beep. If I let go of the buttons it looks like I am in service mode as pushing buttons will toggle some red lights but I never hear a beep. I have tried different settings like going into service mode and then toggle to the first setting and trying it and I still get an end of cycle alarm beep and then going in again and trying the second setting and I still get an end of cycle beep. I'm guessing since I never hear a beep that I'm not in the correct mode to disable the alarm.
Are there new/different instruction to disable the alarm with new/replacement control modules? I can take it apart and remove the beeper from the control board but I am getting really tired of taking this unit apart.
HumboldtRepairMan
#2 Posted : 12 years ago
HumboldtRepairMan
Did you program the new main control after you put it in? The new control should of had a procedure to follow by after installing.
nixima
#3 Posted : 12 years ago
nixima
The new control did not come with anything other than the part. The dishwasher seems to go through its cycles fine. Is there a way to tell if programming is required?
