timoteo
#1 Posted : Tuesday, February 5, 2008 1:48:34 PM(UTC)
timoteo
Hints on removing inlet protector to allow inspection of chopper assembly from inside of dishwasher? With hold down screw removed, I cannot seem to loosen plastic protector without fear of breaking it. Broken plastic fork tine found in this area so suspect noise may be a piece that is trapped in the chopper assy area. No noise when filling or when draining.
#2 Posted : Wednesday, February 6, 2008 11:37:37 AM(UTC)
There is a tab on the other side of the inlet protector. Click on the picture to enlarge.
UserPostedImage
