AzVeggieMom
#1 Posted : Tuesday, July 23, 2013 8:56:42 AM(UTC)
AzVeggieMom
Hi, came home Friday night to a warm fridge and freezer. :eek: The lights work, the fan in back bottom works, the control panel in front works (lets me change cold level up/down). The compressor is not turning on. Had a friend test motherboard, looks like only 33 volts leaving board to compressor, that should be 115, and only 1 volt leaving to the sensors, that should be 5 volts. No burn marks on the computer motherboard. :confused: Please let me know, is this a bad motherboard, or should i look to confirm this another way? :confused: Or any other suggestions or ideas? Thank you. Laurie. :)
#2 Posted : Thursday, July 25, 2013 1:52:29 AM(UTC)
Check the motherboard (WR55X10968) in the back. Probably bad solder joints behind the big power relay.
