ken72
#1 Posted : Monday, July 22, 2013 8:51:28 AM(UTC)
ken72
I have tried to repair the unit because it drains very slowly. I replaced the drain pump and put on a new discharge hose to the disposer. I could not find any kinks or clogs in the lines. Hose is elevated. I read somewhere that there might be a problem with a check valve. The only thing that I have seen on this unit was where the drain hose connects to the pump, it is a 90 degree rubber fitting, and it is stamped "do not remove check valve inside". I saw some videos showing that a check valve was under the cover of the lower wash arm, this unit does not have that kind of access. Any ideas would help, this unit also has some kind of sensor in the hole that the filter goes into.:(
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
