Just bought a property with an unused gas range with the oven door's outer glass broken. need to have it replaced
Your model number is missing several digits at the end of it. Here is the link to the model using the partial number you gave. You will have to find the correct unit in the Matching Model Numbers section. Parts for KGRA806 - AppliancePartsPros.comI did look at one of the Door and Drawer Parts sections and it looks like this part may be obsolete so you will have to call the parts people. |
THIS FORUM IS DEAD!!!!!!! |
