checked for ice on the coils. Were the evaporator coils heavily iced/frosted up?
I unplugged the unit for about four hours to defrost any ice I couldn't see and it soaked a bath towel.
This does sound like you have a defrost problem.Now two weeks later the ice cream is mush and the fresh food section is at 60 degrees.
Again sounds like a defrost problem.Remove the cover so you can see the evaporator coils and determine if there is a defrost problem.
Force a defrost cycle. I beleive your defrost timer is at the top of the fresh food section. There is usually a hole that you can insert a screwdriver into and turn the defrost timer cam. Turn it till the compressor and evaporator fans turn off. You are now in defrost.
Check to see if the defrost heater comes on. Be careful you do not burn your fingers.
If it does heat the defrost timer is shot.
If not the problem could be the defrost heater or defrost thermostat.
Note that this does not totally eliminate the timer as a cause. It could be it's contacts are shot.
Check heater and thermostat for resistance.
Here are a couple good troubleshooting help sites.
http://www.applianceaid.com/refrigerator.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
