Gordie
#1 Posted : Wednesday, October 7, 2009 8:24:34 PM(UTC)
Gordie
I noticed a warming of the fresh food compartment a month ago and the freezer seemed to be freezing @ 15 degrees while the fresh food section went to 40+ degrees. I vacuumed the condenser on bottom and back and checked for ice on the coils. I unplugged the unit for about four hours to defrost any ice I couldn't see and it soaked a bath towel. After plugging the unit back in, it seemed to work fine. Now two weeks later the ice cream is mush and the fresh food section is at 60 degrees. HELP!
#2 Posted : Thursday, October 8, 2009 5:14:04 AM(UTC)
Were the evaporator coils heavily iced/frosted up?
This does sound like you have a defrost problem.
Again sounds like a defrost problem.
Remove the cover so you can see the evaporator coils and determine if there is a defrost problem.
Force a defrost cycle. I beleive your defrost timer is at the top of the fresh food section. There is usually a hole that you can insert a screwdriver into and turn the defrost timer cam. Turn it till the compressor and evaporator fans turn off. You are now in defrost.
Check to see if the defrost heater comes on. Be careful you do not burn your fingers.
If it does heat the defrost timer is shot.
If not the problem could be the defrost heater or defrost thermostat.
Note that this does not totally eliminate the timer as a cause. It could be it's contacts are shot.
Check heater and thermostat for resistance.
Here are a couple good troubleshooting help sites.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Scadaboy
#3 Posted : Thursday, October 8, 2009 11:11:31 AM(UTC)
Scadaboy
Defrost T stat, defrost timer, or defrost heater element. These are all things which control the defrosting of the coils. If any one of these fails, your coils will eventually ice up and your efficiency goes doen the drain.(heats up)
good luck.
