nancybw4333
#1 Posted : Wednesday, July 17, 2013 6:24:07 AM(UTC)
nancybw4333
Suddenly washer will do nothing but final spin no matter the settings. No water in tub, just goes directly to final spin. This washer has not been used much, average 3-5 loads a month. Can this be fixed easily? Is it worth fixing?
HumboldtRepairMan
#2 Posted : Wednesday, July 17, 2013 4:42:52 PM(UTC)
HumboldtRepairMan
Most likely a bad main control board or a loose neutral at the motor check motor connections.
nancybw4333
#3 Posted : Thursday, July 18, 2013 11:45:31 AM(UTC)
nancybw4333
Thanks HumbodltRepairMan. Actually all it needed was to re-set the breaker and then re-set the cycle before turning the breaker back on. Found the directions on the manufacturer's web site. What a relief - saved a bunch![URL="http://forum.appliancepartspros.com/members/humboldtrepairman.html"][/URL]
