Suddenly washer will do nothing but final spin no matter the settings. No water in tub, just goes directly to final spin. This washer has not been used much, average 3-5 loads a month. Can this be fixed easily? Is it worth fixing?
Most likely a bad main control board or a loose neutral at the motor check motor connections.
Thanks HumbodltRepairMan. Actually all it needed was to re-set the breaker and then re-set the cycle before turning the breaker back on. Found the directions on the manufacturer's web site. What a relief - saved a bunch![URL="http://forum.appliancepartspros.com/members/humboldtrepairman.html"][/URL]
