Hello experts,
I have a GE GSH25KGPA with water/ice. A few days ago I noticed an odd change. When I requested water, there was a half second delay before it actually started coming out. Today, it stopped all together. Upon investigating, I noticed a puddle at the back right side on the ground. When water is requested, I see drops a few seconds after under the fridge.
Not sure if this will leak when the unit attempts to make ice.
Ideas?
update:
took the back off and the water tube that comes from the blue connector on the valve was split. it later broke off. I have enough tubing to reach the valve, but the force of the bend on the now shorter tube causes it to leak from the valve.
suggestions?
