sdsvtdriver
#1 Posted : Monday, July 15, 2013 11:22:53 AM(UTC)
sdsvtdriver
Hello experts,
I have a GE GSH25KGPA with water/ice. A few days ago I noticed an odd change. When I requested water, there was a half second delay before it actually started coming out. Today, it stopped all together. Upon investigating, I noticed a puddle at the back right side on the ground. When water is requested, I see drops a few seconds after under the fridge.
Not sure if this will leak when the unit attempts to make ice.
Ideas?
sdsvtdriver
#2 Posted : Monday, July 15, 2013 3:07:18 PM(UTC)
sdsvtdriver
update:
took the back off and the water tube that comes from the blue connector on the valve was split. it later broke off. I have enough tubing to reach the valve, but the force of the bend on the now shorter tube causes it to leak from the valve.
suggestions?
water leaking in back and not filling the Ice tray (Refrigerator & Freezer Repair)
by shatya 10/11/2008 10:18:56 AM(UTC)
