Greetings and thank you in advance for your time & knowledge - Baking. The oven would heat up. After 8 mins Error code E2 F3 and then lock door with "hot" and unlock when cooled. With Googling it appears to be a sensor issue(?) - Decided to do an oven clean this morning and I see bottom element is not on. Could that be from the sensor? or the cause of the E2 F3?
- Also a link to the repair manual would be greatly appreciated.
Thank you for helping me (obi wan)
Originally Posted by: Senseijeff  Greetings and thank you in advance for your time & knowledge - Baking. The oven would heat up. After 8 mins Error code E2 F3 and then lock door with "hot" and unlock when cooled. With Googling it appears to be a sensor issue(?) - Decided to do an oven clean this morning and I see bottom element is not on. Could that be from the sensor? or the cause of the E2 F3?
Thank you for helping me (obi wan) UPDATE... Now 1.5 hours into cleaning I now see the bottom element is on. I guess the top element was brighter at the beginning. So maybe just the sensor? Thanks!!!
Now after the oven self cleaning... it heats up and stays heated without the error code coming up (after about 8 minutes). Guess the sensor is temperamental ?
