Senseijeff
#1 Posted : Sunday, July 14, 2013 8:24:47 AM(UTC)
Senseijeff
Greetings and thank you in advance for your time & knowledge
- Baking.
The oven would heat up. After 8 mins Error code E2 F3 and then lock door with "hot" and unlock when cooled. With Googling it appears to be a sensor issue(?)
- Decided to do an oven clean this morning and I see bottom element is not on.
Could that be from the sensor? or the cause of the E2 F3?
- Also a link to the repair manual would be greatly appreciated.
Thank you for helping me (obi wan)
Senseijeff
#2 Posted : Sunday, July 14, 2013 8:49:34 AM(UTC)
Senseijeff
- Baking.
UPDATE... Now 1.5 hours into cleaning I now see the bottom element is on. I guess the top element was brighter at the beginning. So maybe just the sensor? Thanks!!!
Senseijeff
#3 Posted : Sunday, July 14, 2013 1:35:02 PM(UTC)
Senseijeff
Now after the oven self cleaning... it heats up and stays heated without the error code coming up (after about 8 minutes). Guess the sensor is temperamental ?
