eschutt
#1 Posted : Thursday, July 11, 2013 5:11:14 AM(UTC)
eschutt
Good Morning,
Just a quick question for anybody who might know. Had to disassemble the washer to remove a small metal part between the inner and outer tub. Noticed that my manual says there is supposed to be a check valve on the pump. Don't see a check valve, wondering if it might be located in the drain hose (just after the elbow bend that attaches to the pump.)
#2 Posted : Friday, July 12, 2013 12:41:33 AM(UTC)
Part number: AP4359940
If you look at the pumps outlet you will see a couple orange bits.
I believe these are the clip ins for a rubber flapper type valve.
unlandano
#3 Posted : Friday, July 12, 2013 6:48:24 AM(UTC)
unlandano
Groups: Banned Users
