Good Morning,
Just a quick question for anybody who might know. Had to disassemble the washer to remove a small metal part between the inner and outer tub. Noticed that my manual says there is supposed to be a check valve on the pump. Don't see a check valve, wondering if it might be located in the drain hose (just after the elbow bend that attaches to the pump.)
Part number: AP4359940
If you look at the pumps outlet you will see a couple orange bits. I believe these are the clip ins for a rubber flapper type valve. |
THIS FORUM IS DEAD!!!!!!! |
Groups: Banned Users
