Hi, was fixing the model stove as mentioned above... the rear left element and limiter has a few wires attached to it. One of these has burnt off. It obviously doesn't work now. It was shorting to the upper metal top, but I have capped it off temporarily... I believe that it's been fixed before with inferior components ( not high temp disconnects) All I need to fix this a high temp 90 degree female disconnect and about 6" of high temp wire... does anyone know if I can get this as like spare parts... Do you know the guage? I'm guessing it's #14 or 12 awg, probably MTW, or something like that... I believe it's probably part of a harness ass'y, but do not want to buy the complete harness ass'y if all I need is 6-8" of High Temp wire and a connector... could you please steer me in the right direction?:cool:
