gs1737
#1 Posted : 12 years ago
gs1737
I have a Thermador Gas Range PRD366G that has the following problem.
The oven doesn’t work properly. On bake or convection bake the igniter lights the oven, it runs for 40 seconds makes a click (which I assume is a valve shutting the gas off) and it goes out, 20 seconds later you hear the igniter going again, it reignites and continues this cycle. It takes 30 minutes to get to 400. Now if you put on broil it works fine.
Any help will be deeply appreciated!
Thermador Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by mommyoven 16 years ago
