We have a Thermador oven that won't heat up. Turned it on to 350 to heat up and stays cold. Gas stove works fine. Ordered a new mother board to see if that was the problem...it is installed and still not heating u p. What is the problem?
Same here. Mine will reach temperature some times but it is not consistant. I've seen a few others here with the same problem but I haven't seen a solution. Maybe we can figure it out...
What did you replace?
Did you ever figure out what was wrong? Mine is doing the same thing and all the other posts concerning this issue have gone unresolved. I have replaced the heating element and control panel to no avail.
