alisaab
#1 Posted : Wednesday, June 19, 2013 9:43:07 PM(UTC)
alisaab
When microwave door is closed and microwave is not in use the fan keeps on running. I have to leave the door open or unplug it for the fan not to run. I ordered a door switch from your site and it did not fix the issue, what else could be the issue here. Thank you.
alisaab
#2 Posted : Wednesday, June 26, 2013 5:05:47 PM(UTC)
alisaab
Fan motor checked out ok, any new suggestion?
alisaab
#3 Posted : Wednesday, June 26, 2013 9:46:32 PM(UTC)
alisaab
One thing I forgot to mention was that there was a spark/flash and since then fan running issue started in case if this provides any clue to a solution.
