When microwave door is closed and microwave is not in use the fan keeps on running. I have to leave the door open or unplug it for the fan not to run. I ordered a door switch from your site and it did not fix the issue, what else could be the issue here. Thank you.
Fan motor checked out ok, any new suggestion?
One thing I forgot to mention was that there was a spark/flash and since then fan running issue started in case if this provides any clue to a solution.
