Mar-Gun
#1 Posted : Wednesday, June 19, 2013 2:25:12 PM(UTC)
Mar-Gun
Manufature Date 01-10. OK so it just stoped running one day. Yes there is Power going to it, the Breaker is on and I have 220v inside the Unit. The Light comes on inside. Ok so I Ohm'd out the Start Stop Switch and its OK. I have no Heat, and the Motor dose not turn. Whats Up?
#2 Posted : Thursday, June 20, 2013 3:08:35 AM(UTC)
Parts for Frigidaire FEQ332ES0 Dryer - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...f/Webster/134064000e.pdf
You should not have heat unless the motor is running. There is a centrifugal switch on the motor that activates when the motor gets close to operating speed. One of them switches in power to the heating coil.
I would check the thermal limiter (item 36 in the Cabinet/Drum Parts section) next. It should be 0 ohms.
If it is blown:
1. Check/clean your vent system. Tis is the most common cause of it blowing.
2. Check/clean the bower.
3. Disconnect the heating coil and check it for resistance. it should be about 12 ohms. Then check from each heater connector to the frame/case. Both should be infinite ohms. Sometimes a heating coil can short to the frame and then part of it overheats and blows the fuse.
Mar-Gun
#3 Posted : Tuesday, July 2, 2013 2:19:54 AM(UTC)
Mar-Gun
Originally Posted by: denman Go to Quoted Post
If it is blown:
You Hit the Nail right on the Head! I got my $7 part today and it back up and running. Forum at its best. Thankyou......
