supersport
#1 Posted : Monday, June 17, 2013 8:16:40 AM(UTC)
supersport
Hello, I have a Jenn-Air gas range Jenn-Air JGS8860BDP that the left front burner is continue to clicks even after the flame is present. All other burner are working fine. I already replaced the burner assembly. Thanks for the helps.
Tonu
#2 Posted : Friday, September 13, 2013 5:24:28 PM(UTC)
Tonu
We have the same problem (for right rear) same model JGS8860BDP
