Hello, I have a Jenn-Air gas range Jenn-Air JGS8860BDP that the left front burner is continue to clicks even after the flame is present. All other burner are working fine. I already replaced the burner assembly. Thanks for the helps.
Originally Posted by: supersport  Hello, I have a Jenn-Air gas range Jenn-Air JGS8860BDP that the left front burner is continue to clicks even after the flame is present. All other burner are working fine. I already replaced the burner assembly. Thanks for the helps. We have the same problem (for right rear) same model JGS8860BDP
