Replace water inlet valve on machine and water never stops running into the reservior
Groups: APP Team
Hi. Here is the correct water valve for your model Part number: 2315509
You can test where the problem is by unplugging the icemachine when the water is coming inside. If the water stops then the controls are bad, if not - the water valve has to be replaced again. Please, post the results. Simon.
