Ray Goodman
#1 Posted : Wednesday, June 12, 2013 12:43:22 PM(UTC)
Ray Goodman
Replace water inlet valve on machine and water never stops running into the reservior
Simon / APP Team
#2 Posted : Wednesday, June 12, 2013 2:32:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the correct water valve for your model
Part number: 2315509
You can test where the problem is by unplugging the icemachine when the water is coming inside.
If the water stops then the controls are bad, if not - the water valve has to be replaced again.
Please, post the results.
Simon.
