I just installed a used Fisher Paykle 2 drawer dishwasher. Everything seems to run well enough except when I use the top drawer water winds up in the bottom one. When I use the bottom one water evens goes into the top one. Both are at the end of the cycle. Hoses are clear and not kinked but I suspect the water is going thru the Y hose joiner. I had to extend the drain hose because of a long distance to the drain. There is another cabinet between the diswasher and sink Any suggestions. I was thinking to run separate drain hoses.
Groups: APP Team
H.
Most likely the problem is with the both check valves. It's just a simple rubber flapper placed at the beginning of the drain hose. Unfortunately, we do not carry the parts for FP appliances. Contact the manufacturer.
Simon.
