tomok
#1 Posted : Tuesday, June 11, 2013 8:10:48 AM(UTC)
tomok
I just installed a used Fisher Paykle 2 drawer dishwasher.
Everything seems to run well enough except when I use the top drawer water winds up in the bottom one.
When I use the bottom one water evens goes into the top one.
Both are at the end of the cycle.
Hoses are clear and not kinked but I suspect the water is going thru the Y hose joiner.
I had to extend the drain hose because of a long distance to the drain.
There is another cabinet between the diswasher and sink
Any suggestions.
I was thinking to run separate drain hoses.
Simon / APP Team
#2 Posted : Tuesday, June 11, 2013 3:50:35 PM(UTC)
Simon / APP Team
Groups: APP Team
H.
Most likely the problem is with the both check valves. It's just a simple rubber flapper placed at the beginning of the drain hose.
Unfortunately, we do not carry the parts for FP appliances. Contact the manufacturer.
Simon.
