My dishwasher will continuously fill with water from side wall inlet. Is the problem in the water inlet valve at bottom of washer or in the valve on the side of the wall where water is coming out off.
dishwasher fills with water nonstop from sidewall water inlet. is this a problem with sidewall valve or water inlet valve at bottom?
Groups: APP Team
Hi. If the water continuously coming into the dishwasher when the door is open, you have a bad water inlet valve Part number: W10158389
