massimo
#1 Posted : Monday, June 10, 2013 2:49:05 PM(UTC)
massimo
My dishwasher will continuously fill with water from side wall inlet. Is the problem in the water inlet valve at bottom of washer or in the valve on the side of the wall where water is coming out off.
massimo
#2 Posted : Monday, June 10, 2013 2:57:03 PM(UTC)
massimo
dishwasher fills with water nonstop from sidewall water inlet. is this a problem with sidewall valve or water inlet valve at bottom?
Simon / APP Team
#3 Posted : Monday, June 10, 2013 3:54:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the water continuously coming into the dishwasher when the door is open, you have a bad water inlet valve Part number: W10158389
When replacing the valve be careful not to break the shot off valve under the sink. That could be a problem!
Here are the breakdown diagrams and Fill and Overfill parts for Whirlpool DUL240XTPS7 - AppliancePartsPros.com
Thank you.
Simon.
