mreves
#1 Posted : Monday, June 10, 2013 8:21:30 AM(UTC)
mreves
My dryer is not blowing heat. I've been googling problems, but I have some questions with some details. Everything says a dryer has two circuits on the breaker, but mine only has one, big double breaker, so I guess that's good. The lint hose is clear. The heating coils are not heating up when running, but they do have current running through them, confirmed with my handy voltage tester. Literally, hand hand is still tingling! So what would it be with current going to the coils but them not heating up? Thanks.
#2 Posted : Monday, June 10, 2013 9:58:11 AM(UTC)
Parts for Estate TEDS840PQ1 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram
[COLOR="Blue"]Everything says a dryer has two circuits on the breaker, but mine only has one, big double breaker, so I guess that's good.[/COLOR]
Yes it is probably OK. It should disconnect both sides of the line.
Since you mentioned the breaker has this unit ever worked with this electrical set up.
I would try flipping it off/on slowly. Sometimes you can loose half the line without tripping the breaker.
The coils can have voltage but if they are open no current will flow.
I do not know how much electrical you know so perhaps the foll0owing will help you.
Your hose electrical is actually two 120 volt supplies with a common Neutral but they are 180 degrees out of phase. So when one is at positive 120 volts, the other is at negative 120 volts. You then get 240 volts between the two (l1 to L2).
The heating coils require the full 240 volts as they are not hooked to Neutral.
The shock you received may have been just from 120 volts.
The first thing to do is to make sure the unit is getting 240 volts with a meter. Use a AC voltage scale that is higher than 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is good then you can unplug the unit and use resistance.
This is a much safer way to check things.
The heating coil should be 8 to 12 ohms.
The thermal cutoff, hi-limit thermostat and operating thermostat should all be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
TEDS840.pdf (177kb) downloaded 0 time(s).
mreves
#3 Posted : Wednesday, June 12, 2013 7:29:32 AM(UTC)
mreves
So if the coil is getting enough power then what is my problem. The coil just bad? The thermostat bad? Something else.
#4 Posted : Wednesday, June 12, 2013 10:28:34 AM(UTC)
If the coil has 240 volts across it and does not heat up then it is bad.
Note that it is easier and safer to check the heating coil with a meter for resistance with the unit unplugged.
