Parts for Estate TEDS840PQ1 Dryer - AppliancePartsPros.comSee the attachment for your wiring diagram
[COLOR="Blue"]Everything says a dryer has two circuits on the breaker, but mine only has one, big double breaker, so I guess that's good.[/COLOR]
Yes it is probably OK. It should disconnect both sides of the line.
Since you mentioned the breaker has this unit ever worked with this electrical set up.
I would try flipping it off/on slowly. Sometimes you can loose half the line without tripping the breaker.
The heating coils are not heating up when running, but they do have current running through them, confirmed with my handy voltage tester. Literally, hand hand is still tingling! So what would it be with current going to the coils but them not heating up?
The coils can have voltage but if they are open no current will flow.
I do not know how much electrical you know so perhaps the foll0owing will help you.
Your hose electrical is actually two 120 volt supplies with a common Neutral but they are 180 degrees out of phase. So when one is at positive 120 volts, the other is at negative 120 volts. You then get 240 volts between the two (l1 to L2).
The heating coils require the full 240 volts as they are not hooked to Neutral.
The shock you received may have been just from 120 volts.
The first thing to do is to make sure the unit is getting 240 volts with a meter. Use a AC voltage scale that is higher than 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
If the power is good then you can unplug the unit and use resistance.
This is a much safer way to check things.
The heating coil should be 8 to 12 ohms.
The thermal cutoff, hi-limit thermostat and operating thermostat should all be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
