ice maker not getting water. I replaced the emitter- receiver control board and got it running for 3 weeks. now its not working again.
Groups: APP Team
Hi.
Are you getting the steady LED light when the flapper door is pushed in?
If you do - then check if the water supply tube is not frozen, if it is - you need to replace the water inlet valve.
Post the results.
Simon.
