Refrigerator and freezer not cooling. Nothing runs and the display inside the door is flashing HRS. The temp. display is not working. The lights are working but nothing else. Thanks
Groups: APP Team
Hi. The HRS code means that your refrigerator need a service. There is a problem with the main control board located at the back of the fridge. it's covered by the metal plate. Unplug the fridge, remove the cover and replace the control board Part number: WR55X10942
