robforster
#1 Posted : Thursday, May 23, 2013 4:32:17 AM(UTC)
robforster
Bottom freezer keeps forming ice, even after leaking ice maker was removed. Moisture is forming somehow on the bottom of the freezer causing this problem. The rest of the thing works just fine and it keeps things frozen, looking for a possible solution.
#2 Posted : Friday, May 24, 2013 2:24:13 AM(UTC)
The moisture you are seeing is probably from the defrost cycle.
It should drain out a hole below the evaporator coils at the back of the freezer and then down into the drip tray under the unit. This water then evaporates.
I looked at the Sears parts site but could not see exactly where this drain is.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tray after you are done.
Be sure to unplug the unit while doing this.
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Kenmore Refrigerator Model 111.72695911 Inverter Board (Refrigerator & Freezer Repair)
by jppreble 11/2/2023 2:34:22 PM(UTC)
Kenmore refrigerator model#106.59592992 (Refrigerator & Freezer Repair)
by Guest 5/16/2023 12:53:20 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
Kenmore Refrigerator trips GFCI (Refrigerator & Freezer Repair)
by A_A_Ron 7/1/2022 11:38:52 AM(UTC)
Kenmore refrigerator breathing (Refrigerator & Freezer Repair)
by Guest 1/3/2022 3:24:07 AM(UTC)
Reading codes from Kenmore Refrigerator (Refrigerator & Freezer Repair)
by caribconsult 11/29/2021 3:18:54 PM(UTC)
Kenmore refrigerator 'ER - dH' code (Refrigerator & Freezer Repair)
by Kanehs 9/22/2020 9:47:19 PM(UTC)
Kenmore Refrigerator Ice Crusher (Refrigerator & Freezer Repair)
by JOSHSKORN 4/27/2020 11:48:08 AM(UTC)
Kenmore refrigerator 3 beeps (Refrigerator & Freezer Repair)
by bluefitness 3/3/2019 5:37:06 AM(UTC)
Kenmore refrigerator: 106.64252402 (Refrigerator & Freezer Repair)
by SGH 1/1/2019 12:39:12 PM(UTC)
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Kenmore Refrigerator not cooling (Refrigerator & Freezer Repair)
by Doug615 5/14/2016 12:27:12 PM(UTC)
Kenmore refrigerator not dispensing water into ice tray (Refrigerator & Freezer Repair)
by Jmfreddy17 1/6/2016 3:10:02 PM(UTC)
Filler tube for Kenmore refrigerator (Refrigerator & Freezer Repair)
by kidcapri73 6/24/2015 2:41:34 PM(UTC)
