ig4468
#1 Posted : Tuesday, May 21, 2013 7:41:26 PM(UTC)
ig4468
hello all
i was using my cooktop the other day and it stopped heating and it also had an electrical burnt smell. the control panel is dead noting works on it unless you turn one off the cook top knows to the on position. then you can set bake etc to temp but will still not heat up fault code is f3be or f36e im not sure but i replaced the control panel and still noting.. any help would be great .
#2 Posted : Wednesday, May 22, 2013 1:30:07 AM(UTC)
Parts for Whirlpool WFE381LVS0 Range - AppliancePartsPros.com
"noting works on it unless you turn one off the cook top knows to the on position."
I am assuming that the above has a couple typos and you mean :
nothing works on it unless you turn one of the cook top knobs to the on position.
You may have a power problem re: no L1 voltage.
What happens is that the L2 voltage feeds back trough the stove top element switch and this then powers up the control board. You of course get no heat as the elements require L1 to L2 voltage (240 volts).
I would check the wiring in the unit before starting the below just to be sure that a wire has not shorted out and was the cause of the burning smell.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
File Attachment(s):
WFE381.pdf (250kb) downloaded 2 time(s).
Whirlpool Help, Bake does not work (Oven Repair (including Ranges and Cooktops))
by djrhineh 12/28/2014 4:59:00 PM(UTC)
Whirlpool help (Dishwasher Repair)
by Ront16 8/18/2012 2:25:38 PM(UTC)
Whirlpool Help (Refrigerator & Freezer Repair)
by jojo87 12/4/2011 7:00:15 AM(UTC)
by parks71 11/29/2007 4:14:53 PM(UTC)
