rfm1
#1 Posted : Tuesday, May 21, 2013 3:54:45 AM(UTC)
rfm1
Washer fills fine and when the level is full it cycles to wash and you here the motor humming. I pulled the front cover off and the motor,belt and transmission pulley are all turning but no agitation??
fairbank56
#2 Posted : Tuesday, May 21, 2013 4:42:40 AM(UTC)
fairbank56
Groups: Expert
If you can easily rotate the lower agitator by hand, the splines are probably stripped inside the agitator coupler. If so, remove the agitator by placing a strap under it and yanking up forcefully to pop it off. Then remove the bolt holding the coupler and inspect the internal splines. If this is not the problem, then you have a faulty transmission.
Eric
GE Washer Not Agitating or Spinning (Washer Repair)
by Gator84 8/17/2015 4:34:56 PM(UTC)
by KerriH 7/19/2013 9:06:57 AM(UTC)
GE Washer Not Agitating (Washer Repair)
by eosada 2/17/2013 6:10:32 AM(UTC)
GE washer not agitating properly (Washer Repair)
by aav 6/23/2012 8:30:14 AM(UTC)
by skeeskinner 12/20/2011 5:15:24 PM(UTC)
GE washer not agitating (Washer Repair)
by Ellen Clark 8/15/2011 8:36:42 PM(UTC)
GE Washer Not Agitating, Transmission Fine (Washer Repair)
by silvz72 6/9/2010 9:09:12 AM(UTC)
by penninger7142 5/7/2009 5:07:20 PM(UTC)
