My washing machine has stopped agitating and I assume it is from an oversize load we tried to wash (comforter). We've tried to diagnose what went wrong. The belt is still on, and I can turn motor clutch by hand, thereby turning the belt and it turns the transmission and drum fine. I assume it is the motor. Is there a way to know for sure? Is there some kind of "reset" to try first? It seems like something else would go out first before the motor would burn up.
THIS FORUM IS DEAD!!!!!!! |
