Ruff
#1 Posted : Wednesday, May 15, 2013 9:16:05 PM(UTC)
Ruff
Washer has no let lights and makes no noise! I have checked for power and it is good at junction box. Where do I go next? Thanks for any HELP!
Joe / APP Team
#2 Posted : Thursday, May 16, 2013 2:09:34 PM(UTC)
Joe / APP Team
Ruff, The next check will be the door switches on the latch assembly
Part number: AP3774457
Check and make sure you have 120 VAC across the wires into the switches. some times the wiring at the bottom of the door break, due to usage over the years. if you have the voltage at the switches, and check voltage at the control board (across black wire connector P1 pin1 and white wire P3 pin7, if you have the voltage, you'll need to start at the console keypad assembly
Part number: AP3210664
Ruff
#3 Posted : Monday, May 20, 2013 2:30:35 PM(UTC)
Ruff
Broken wire! Thank's a million!
Joe / APP Team
#4 Posted : Tuesday, May 21, 2013 6:04:27 AM(UTC)
Joe / APP Team
Ruff, Great !! Glad it was nothing "major"
Glad we could help.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
