Washer has no let lights and makes no noise! I have checked for power and it is good at junction box. Where do I go next? Thanks for any HELP!
Originally Posted by: Ruff  Washer has no let lights and makes no noise! I have checked for power and it is good at junction box. Where do I go next? Thanks for any HELP! Ruff, The next check will be the door switches on the latch assembly Part number: AP3774457
Check and make sure you have 120 VAC across the wires into the switches. some times the wiring at the bottom of the door break, due to usage over the years. if you have the voltage at the switches, and check voltage at the control board (across black wire connector P1 pin1 and white wire P3 pin7, if you have the voltage, you'll need to start at the console keypad assembly Part number: AP3210664
Broken wire! Thank's a million!
Originally Posted by: Ruff  Broken wire! Thank's a million! Ruff, Great !! Glad it was nothing "major" Glad we could help.
