bbrothers726
#1 Posted : Monday, May 13, 2013 4:44:49 PM(UTC)
bbrothers726
Everything seems to be running. Fan at the bottom, fan in the back of freezer. Compressor is a little warmer then room temp. I am thinking relay on the compressor is bad.
#2 Posted : Monday, May 13, 2013 6:42:13 PM(UTC)
Does the compressor vibrate when the fans are running?
Here are the breakdown diagrams and Parts for Whirlpool ET8MTMXKT00 Refrigerator - AppliancePartsPros.com
bbrothers726
#3 Posted : Tuesday, May 14, 2013 2:58:05 AM(UTC)
bbrothers726
It vibrates a little bit yes. Nothing noticable unless you feel the compressor. It shoots cold air out the back of the refrigerator but that is also part of the fan blowing.
#4 Posted : Tuesday, May 14, 2013 2:22:28 PM(UTC)
Remove the rear panel in the freezer and check how the evaporator coils are covered with frost. If the coils are clean, there is a problem with the sealed system. Probably it's low on Freon.
bbrothers726
#5 Posted : Wednesday, May 15, 2013 2:55:40 AM(UTC)
bbrothers726
They coils were clear, but i checked when it was off for a while. Am i able to charge it with freon?
#6 Posted : Wednesday, May 15, 2013 4:29:23 PM(UTC)
Originally Posted by: bbrothers726 Go to Quoted Post
...Am i able to charge it with freon?...
I do not think so. You will need some special equipment and most important, if it is low on Freon then there is a leak somewhere and it must be fixed first.
Let the refrigerator run for 1 or 2 hours and check the coils again.
